Codesys 2.3 Libraries - Creating Your Own
SilverShotBee
May 2011
England
46
I have created my own standard libraries, but have run in to an issue I hadn't expected.
Inside my library file, I have imported other libraries, manufacturer libraries for the PLC I am using. Now, I thought that if I'd imported a library in to another library file, I'd only need to import that one library file to have access to the function blocks of all libraries inside the one loaded.
Sadly, that doesn't seem to be the case and I simply get a ton of errors saying "Function [XXX] doesn't exist" (or something like that). If I import the libraries that are already imported in to the master library, all works fine.
Is there something I am doing wrong here, or is this just a limitation of Codesys / to stop license issues ect.
it is both a licese issue and you can notimport a compiled library.
see oscat.de for a very good load of functions.
Thanks, I thought it might be something along those lines. Shame though! I guess I'll just have to list the other libraries that are required in order for this one to function correctly.
Hello everyone, I'm stepping into some Codesys stuff for the first time and it seems not many people know much about it. Does anyone know in...
7,187
More Codesys help after my question earlier which was answered by Norm. I'm having trouble creating a custom library, I've created one function...
2,425
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
298
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
162
