CoDesys as DCS
KalleOlsen
Oct 2008
Norway (moustache area)
1,782
Hi!
Has anyone of you guys experience with Codesys or derivats (Twincat) in really big configurations? I mean, with several ten-thousand IOs. Is it comfortable to maintain and make changes on a running process? Are there any HMI solutions for integrarion of automatically generating (and removal) of icons and alarms? (Today I'm using Siemens PCS7 - works very well and is expensive.)
Kalle
Not had any experience with high I/O count as just starting out with Beckhoff equipment, but I know the Beckhoff EtherCAT system is supposed to scan 12,000 I/O in just over a third of a second, and they do a large selection of I/O cards as well as fieldbus modules.
http://www.beckhoff.com/english.asp?ethercat/default.htm
There are many HMI solutions that provide drivers for the TwinCAT ADS interface. I use Indusoft WebStudio, but I am sure there are others on here who would have there own favourites. You could also look at the TwinCAT OPC server.
Jon.
Correction: When I look at following link it says they can scan 1.000 I/O in 30µs, so that means they scan 12.000 I/O just over a third of a millisecond.
Jon.
Sorry my brain is not functioning today. It is Sunday afterall.
I read micro seconds but automatically told my brain it was milliseconds.
Jon.
First a disclaimer: I dont have any practical experience with CoDeSys or TwinCat.
As far as I can tell, a major deficiency for Twincat to cover systems in the scale that is normally covered by DCS is the total lack of both CPU and i/o redundancy.
Beckhoff and TwinCat seems to be particularly targeted at machines and smaller processes.
There are many Scada softwares that are compatible with Beckhoff and Twincat, but I dont think any has the level of integration that for example PCS7 has.
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
164
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
337
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
100
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
168
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
525
