Codesys E-Learning
userxyz
May 2002
any
2,768
Hi All,
I used Codesys for Lenze Servo drives recently.
Now I've seen that Mitsubishi is certified for PLCOpen since 2015.
I am a Siemens Certified Programmer, but I am more and more interested in Codesys as I will need it more in the near future.
Is the E-Learning any value ?
Anyone experience with the online course ?
Kind regards,
Combo
for an experienced programmer, just forget all these tweeks and program just the simple way. and yes E learning is good, however probably to slow and cumbersome for you.
Assuming you have access to hardware... wouldn't a raspberry pi running Codesys be a good starting point?
I think if you're used to TIA Portal, and from my time playing with Codesys, I think a lot of it (apart maybe from the hardware config) will be easy to pick up by implementing some sort of functionality.
If you have a place to test with hardware by yourself, then e-training may be a good solution, otherwise, I found that it's always best to have something to mess with right there and then.
download codesys for free, and start simulation. yes a RPi is a cheap start, however when a bit further buy a cheap codesys machine.
I've recently inherited a project from one of our sister companies. We have a range of machines that all use various versions of Codesys. I'm...
2,660
I'm beginning a new job soon and the next place uses only Wago PLC's. All of my previous experience is in RSLogix 500/5000 and DirectLogic. I'm...
3,608
Hi guys! really enjoyed reading the threads about the different "languages" used in programming PLC... learned a lot! anyway, i just want to ask...
9,625
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
296
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
