CODESYS Gateway does not start, cannot scan CODESYS devices
AlfredoQuintero
Feb 2015
Yokohama
1,552
Hello:
I have a problem I had never seen before with CODESYS and it seems to have happened after I added some new installation to this Windows workstation.
As shown on the screenshot below, the CODESYS gateway does not start, and as a result it is not possible to scan CODESYS devices. Looked into CODESYS forums and there are a number of similar inquiries but no explanation on the resolution.
Would be very helpful if someone has found this issue and could share a solution.
In CODESYS Installer, Settings, change the default gateway to the version you want to use ( and back again). #random-troubleshooting-ideas
Once again, AustralIan, you have come to the rescue.
Your solution worked. Thanks so much.
paraffin power, thanks for your comments too.
hi, I am currently working on a project that requires access to the data inside plc using Codesys OPC server v2.3 and I want the data to be...
3,025
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
299
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
162
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
514
