Codesys V3.5 SP17 Pach 1, Win V3 x64, "No device is responding..."
AlfredoQuintero
Feb 2015
Yokohama
1,570
Hello. After installing the latest Codesys V3.5 SP17 Pach 1, Win V3 x64, on some of our Windows 10 workstations it is impossible to load a program to the Win V3 x64 because it always gives the error "No device is responding to the scan request".
Any hint on what to check to fix this issue? On different Windows 10 PCs everything works as expected, yet I am not aware of difference in the Windows 10 or Codesys installation. With the previous Codesys v3.5 SP17 we did not have this problem.
Thanks for your comments.
Hello! I use CheckBounds (POUs for Implicit Checks). But I have a problem. I use an array as an VAR_IN_OUT of Function Block. If I try to monitor...
505
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
74
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
195
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
424
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
115
