Codesys Visualization...Rotate Image
jonfarrugia
Mar 2008
London
130
Im Looking for a way in codesys visualization to rotate an image based on a variable. I know the polygon is the only object that allows rotation but I'm trying to find a way to add an image into the polygon...Any suggestions? Im using version 2.3
http://www.wago.com/wagoweb/documentation/759/eng_manu/333/m07590333_00000000_2en.pdf
It does not appear that this can be done.
A variable in the Angle field causes the element to turn on its turning point, depending on the value of the variable. (Positive Value = Mathematic Positive = Clockwise). The value is evaluated in degrees. With polygons, every point rotates; in other words, the polygon turns. With all other elements, the element rotates, in such a way, that the upper edge always remains on top.
Regards,
Is there any way to bind more than one variable to a Text field? I want to be able to doing something like this <Value> <Unit> 104.6 F or...
4,042
I dont see image in Codesys Visualization Lamp or Switch .
1,346
hello all, i have done visualization to have a model of elevators(auto car parking)....now i want to program it in such a way that when i enter...
3,048
what are the steps for recipe management in visualization scada of codesys in ABB plc ??
2,472
Does any1 knows the steps for recipe management in visualization scada of ABB codesys plc ??
3,487
