Cognex Camera , ControlLogix , and 3D Image on HMI ?
Rob S.
Sep 2008
Maryland
739
I was in a brainstorm session last week and we were discussing using maybe 2 Cognex cameras to come up with a 3D image. Using a ControlLogix PLC I can capture all the measurements the camera is seeing . I was wondering if their is a HMI or other software (most likely ) that I can interface with the ControlLogix PLC to draw ,in in fairly good detail, the image that the cameras are seeing. I am on a limited budget.
Thanks in advance, Have a great week.
"A limited budget" could be a very relative term when talking about ControlLogix and 2 Cognex cameras.
Anyway, Pro-face 3000/4000 touchscreens series do communicate with ControlLogix PLCs and do have a driver for Cognex which can display an image. Don't really know much about the limitations so it would be better for you to contact someone at Pro-face America to discuss. A 12" Pro-face unit will cost around about $3000.
PS I understand you are not looking at a PC-based solution?
PC Based would be fine. Any ideas with that. Maybe a Autocad type software that would interface with ControlLogix ?
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,248
Hello everyone, PFA. I am not very used to of the Insight system. But this is a general question, Since the 0 line is offset from the right edge...
1,025
Now, I apologize if this is a little off topic, but it is connected to a plc that should send a trigger to the Cognex 5400C camera. Since they're...
4,685
Hi guys, As a topic title says.. If someone would be so kind to point me in a direction.. ATM I am mostly concerned about camera value output...
3,207
I am working on a continuous production line, more in specific where vynil is produced. At some point they have implemented a 'positioning frame'...
3,246
