Cognex Dataman 200 Images To PanelView HMI
rs14smith
Aug 2012
TN
61
I'm trying to figure out how to transfer an image from an FTP server to a PanelView HMI. Cognex allows you to store images on a FTP server, I just do not know how to pull images from that server from within FactoryTalks. Is this at all possible without a lot of headache?
Controls Engineer
If you make an Active X control with Visual Basic or some other program language then you can use the plc to set the string for the filename and path you want to link the image to as the current image on the FTP server. The Insight software comes with examples for the micro series cameras where they provide the active X. But I've done it with other Panelview Terminals displaying images before.
You can look at the following Tech articles on the AB Knowlege base.
519753 - Custom ActiveX Write Tag Instructions and Sample for PanelView Plus 6 and Machine Edition 6.x
119862 - Custom ActiveX Control Instructions and Sample for PanelView Plus 6 and Machine Edition 6.0
117498 - Software Development Kit (SDK) for PanelView Plus 6
Good Luck!
Hello, I am programing a Micrologix 1400 to comunicate with a Dataman 200 from Cognex have some body a MSG ladder example for this PLC Regards
2,620
Hi I'm looking for the assembly instance to connect a Cognex Dataman 200 (2D Barcode reader). Connected to the plc via the e-net card. I'm...
2,503
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
70
Hey guys, I have an older Cognex Dataman scanner that i have added to a machine. I have established comms over ethernet. I am able to trigger...
1,791
I am planning on working with a cognex scanner 370 series using a beckhoff PLC and Ethernet/IP protocol. My question is does anyone know if the...
1,259
