Cognex Dataman
janner_10
Dec 2014
Tewkesbury
1,301
Anyone know if the above can produce to csv, say start a new file on a pc every 5 minutes?
A bit of Googling would suggest at least you can log to csv, but without a reader to hand it a bit tricky navigating the set up tool.
A quick check, I see you can data log w/ the setup tool open. I don't see a quick easy way to start a new file on any frequency however.
You can also transfer the results via FTP and append to a specific file, but I also don't see a way to change those files every 5 mins.
Maybe with some scripting, That might be something to check w/ Cognex on directly.
Several years ago I set up communications between a GE QuickPanel and a Dataman using ModbusTCP. Clicking a button on the HMI would run a script which wrote a command string to the Dataman and then set the string command trigger bit of the command word. The command string was to FTP the image buffer file to the HMI.
I expect you could do something similar with the data. As I recall the FTP procedure always writes to the same file name, so once you receive fresh data, you'll probably have to rename the file with the fresh data so it doesn't get overwritten by the next FTP transaction.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
71
Hey guys, I have an older Cognex Dataman scanner that i have added to a machine. I have established comms over ethernet. I am able to trigger...
1,792
I am planning on working with a cognex scanner 370 series using a beckhoff PLC and Ethernet/IP protocol. My question is does anyone know if the...
1,259
I've exhausted my resources on this one. My customer has thrown 3 Cognex Dataman 262 scanners at me to configure for a project using RSLogix...
4,357
Good Morning , Getting ready for a project using the Cognex Dataman 262QL and interfacing with a CompactLogix 1769-L33ER processor. How...
2,023
