Cognex In-Sight 5000 - Ethernet/IP RSLogix
code128
Aug 2014
UK
[FONT=&quot]I have a Cognex In-Sight 5000 series camera reading a barcode and sending the data string using the WriteEIPBuffer function. The camera is triggered directly by a sensor.
[/FONT]
[FONT=&quot]The data is received by the PLC in the Inspection Results section on the first trigger but on the next trigger the data doesn’t always change/update.[/FONT]
[FONT=&quot]On the third trigger the data from the previous trigger is available.[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]I think this is probably a timing issue. Has anyone experienced this behavior before?[/FONT]
I haven't actually seen that behavior, but I do use the 5000 series camera a decent amount. I normally us the O.Control.InspectionResultsAck output to resent the I.Status.ResultsValid input before triggering, and then watch for I.Status.ResultsValid to go high again before "finishing" my inspection sequence.
Thanks for the quick reply. When you do this do you also have the O.Control.ResultsBufferEnable set to true?
I do not, the only other thing I set (other than the trigger) is the O.Control.TriggerEnable, and that one I just leave on all the time.
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
137
hello all, Im very new to cognex software, and I'm picking up a project where someone that is no longer with us left off... See the attached...
2,119
I have a Cognex In-Sight 5000 Series camera using Ethernet/IP we previously pulled off another machine, with an IP address in the 192.168.0.X...
6,404
Hi all : Has anyone used AOIs designed by cognex to be used with Insight 5000 cameras. Info on their web page is poor, i'd like to use them in...
3,348
The SSV instruction in RS5000 can be used for the Cognex In-Sight 5000 Modules, however, all it shows is mode. What exactly will this do to the...
2,503
