Cognex , Mitsubishi & Ethernet
Steve Etter
Apr 2002
Morristown, TN
965
Hi All,
I am working with a Cognex 5100 camera system and a Mitsubishi Q02 series PLC. Both are connected to a common Ethernet hub and I can communicate with either via my laptop using its Ethernet port.
Currently, there is no communication between the camera and PLC other than the hardwired connections between the PLC and the Cognex I/O board. I am not having any problems with this current set-up, but I would really like to develop additional communications using the Ethernet if possible.
I believe I have enough information to for the Cognex side, but I can’t figure the PLC side.
To start with, I want to write a single value from the camera to the PLC. In the Cognex, I am using the following code:
WriteEIP(1,”0i”,$H$32)
If I understand correctly, this should take the 8 bit value located in cell H32 and write it out into the Ethernet abyss somewhere.
Now all I need is for the PLC to snatch it up and plop it into some location in the PLC.
I am looking at the JP.RECV command, but can’t seem to get it to work. Here is the code I have right now.
Anybody know how to do this or even if it is possible?
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
105
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
137
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
224
Good People of PLCTALK. I am trying to understand the pass-fail on one of our product lines. I was able to record the Cognex images on the...
244
Gents, We have the following configuration: A Beckhoff PLC with EthercatMaster > EK1100 with a EL6652 EthernetIP Master. Plan is to...
394
