colors for the serial cable ??
siggibald
Oct 2012
iceland
60
hei
i have a frozen micro 820 and i have to connect serial rs 232 cable. where can i find the right wire colors for the serial port on the micro 820 ?
hei
In your dreams.
There is no official color code for things like communications cables (wouldn't it be nice?). Even if there was, it would depend on DCE or DTE and so on. Remember, the transmit at one device connects to the receive at the other device, so the code wouldn't always be "red for receive" for example.
I always went to great lengths to document on the system drawings the colors at each termination point. I could only do this on as-builts, because different vendors of multi-conductor cable used different colors.
Good Morning, I am building a panel that has 120VAC, 24VDC, 12VDC, and 5VDC, and was wondering if anyone had any ideas for wire colors. I have...
3,117
Hello, I have been lurking here for awhile and can usually find the answers to my problems. I'm doing my first PanelView application using...
1,272
So, I am covering for a colleague who is out this week, and I started to check out a control panel he had designed. To my surprise, I opened the...
6,579
Kindly, where can we find the Colors of the wires used inside an encoder signal cable? Any international standard for the Colors used on signals...
993
I have a valve in Wonderware that I’d like to change colors within a certain range. This is a Analog value, so what I like to do is the...
1,654
