Combine 5 HMI's into one FT SE Local app
Bob O
May 2003
1,873
Here is what I’m attempting to do.
I have 5 sections of production that are in 5 different PV. Two are PV Classics and 3 are PV+ and I need to bring them all together into one FT SE Local for an overall display.
Here is what I have tried.
Section 1 Main FT ME imported into new FT SE local ok
Section 2 FT ME imported into new FT SE local Ok
Section 3 FT ME imported into new FT SE local Ok
Section 4 PB32 imported into new FT ME and imported into then FT SE local Ok
Section 5 PB32 Imported into new FT ME and imported into then FT SE local Ok
I then exported the tag data bases so I could combine all the tags using excel and then import all the tags back into Section 1 Main SE local but I get errors stating “Unable to add tag to Realtime Data Manager” Tag ID XX already exists plus some syntax errors.
Why didn’t it throw errors when I originally imported\created the individual FT SE local that would be combined later?
Also, I created HMI tag folders for each section and renamed the tags with the correct folder\tagname prior to the tag import. I believe this should eliminate any chance of a duplicate tag name plus organize it a bit more.
Am I headed in the correct direction or is this just going to be a PIA?
Hi; I have installed Weintek HMIs at different machines. I have configured data logging and HMI logs the data in a file having extension...
1,300
1,200
Dear fellows, I need to know what is the protocol which i can use in LS plc to make the schneider HMI and scada work with it . I have alot of...
1,770
I am getting data from a modbus device and I need to combine 2 16 bit N registers in to 1 32bit L register. I have tried a CPW N242:2 -> L245:0...
2,149
Hello Everyone, I am working on CCW 9.0 software with PLC Micro820. I am communicating with Energy meter over Modbus RTU. I...
4,058
