Combining ac and dc relay outputs
viciousvis
Jan 2015
UP
HI..
I need to combine an AC relay output and a DC relay output together for checking of 2 conditions.
Is it feasible? HOw?
I don't understand how you'd "check conditions" with outputs, but an isolated relay output module would be capable of switching both AC and DC circuits. I would, however, typically refrain from mixing AC and DC circuits on the same module in order to avoid AC noise being induced onto the DC circuits.
ok
A motor is tripped by an ac relay getting ac input via a digital display unit (getting value via load cell) and a valve is operated by 24v dc. Now I want valve to operate when motor is operating only.
The word 'I WANT' mostly member dislike you need to change,
maybe -> i try to configure/modified/design bla,bla
you need to search Relay AC/DC coil that can accept same level of voltage and parallel it
That makes sense. And suppose I want one relay to operate only if other does.
like if ac input output relay is on then ac input dc output relay should be on.
for this is it ok to give same ac coil supply to both??
You can string together as many relays as you need, and control as many devices as you care to. You just have to sit down and draw it out and then wire it in whatever configuration suits your purpose. Or have an electrician design and wire it for you.
Hi, I have a functions which extends codes generation for RFID tags. Basically it takes a char and splits it's hex value over 2 chars. I cannot...
24
9,455
I'm onsite right now and I'm trying to decide how to proceed. I need to make some major edits to the Micrologix 1400 file, but the guy with the...
1,161
Hello, I am trying to write a logic to control a pump. I have my logic as attached. Is there a way to do Auto and Manual control without having...
2,721
Hi there, Quick Question. I have 2 PLCs and 2 solenoids. I would like to wire these up so that If either one turns on, it will turn on both...
17
11,418
Hi all. I’m currently trying to combine 3 memory words in to a single display on a weintek hmi as I want to display running time. I have the...
1,832
