Combining HEX
dginbuffalo
Dec 2010
Buffalo,NY
630
I am trying to get data moved from a Modbus node through an Anybus communicator to a Compactlogix PLC. The water temperature 64.7 comes across as two HEX words 2 87. when combined and switched to decimal it is 647 again. How do i accomplish this in the PLC??
I have a 3-axis sensor that I'm working on integrating with a Micrologic PLC. The sensor has a RS-422 output and I'm using an RTA Automation PLC...
3,263
Hi, I have a functions which extends codes generation for RFID tags. Basically it takes a char and splits it's hex value over 2 chars. I cannot...
24
9,525
I'm onsite right now and I'm trying to decide how to proceed. I need to make some major edits to the Micrologix 1400 file, but the guy with the...
1,172
Hello, I am trying to write a logic to control a pump. I have my logic as attached. Is there a way to do Auto and Manual control without having...
2,743
Hi there, Quick Question. I have 2 PLCs and 2 solenoids. I would like to wire these up so that If either one turns on, it will turn on both...
17
11,477
