Comm Cable For Micrologix 1200 PLC?
calinorth
Apr 2015
Stockton
21
Which communication cable should I buy to communicate with a micrologix 1200 plc. I have Windows xp sp 2 running on a virtual machine on my laptop but I only have usb connections available on my laptop. Also I have the keyspan high speed rs 232 to usb adapter that I use for the AB 5/03 PLC's at work. Will my keyspan adapter work with the micrologix 1200 com cable from ab or do I need something else thx in advance :geek:
Keyspan USA-19HS with the 1761-CBL-PM02 cable is the gold standard for communicating with MicroLogix controller serial ports.
I prefer to let the VM connect to them over USB instead of using the virtual COM port; that method tends to be faster.
Having trouble wiring my device into the 1763-NC01 adapter and can't find any good documentation online. The adapter has connections labeled...
10,976
Hi everyone, I have a replacement cable for 1761-CBL-PM02, w/c the other side is RS232. But my laptop don't have that port, instead its a usb...
4,338
R
I have a Allen Bradely 1784-cp7 cable with pin out (9pin female-8pin Mini DIN) (7-3) (5-1) (1-6) respectively. It plugs in but Im afraid to try...
19,081
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
135
I was trying to connect a HMI (EZTouch Panel) to SLC500. The HMI had a PLC port (RS232/RS/422/485) 15 pin D-female connector. The PLC had a RJ45...
2,732
