comm problem between AI2 and PLC2
michaelchan
Jun 2007
FUJIAN PROVINCE
43
Use plc-2 software AI2 talk to plc2/16,I can upload and monitor program before,but today I could not do it with same laptop,cable and 1784-pcmk card,attched is error report.Can anyone tell me what the problem is?
Does anyone have AI2 user manual?
Thank you very much.
Error code indicates it's trying to use the serial port -- is that the path you're intending to use? Or are you trying to use the PCMK? Check your comm setup.
Hi OZEE,I have checked my comm setup,I am sure no problem with it.
I have a try with another computer(98 operating system),error code is 94,code description:pCMK is not at specified socket# or is in use.I check socket number in Rslinx PCMKinfo,the number is 2,but I could not define PCMK SOCKET number into 2,only 0&1 I can put into.
How can I setup correct PCMK socket number?
michael
I've been trying for a while to communicate a G308A TouchScreen with a Micrologix1500. I'm using a CBLGEN01 cable and a "homemade" female to...
4,301
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
537
Hi, I am trying to do a very simple program to communicate the PLC with Hyperterminal. I am using a new CP1W-CIF01 Optional Board (RS232) with...
2,559
Looking for anybody that has experience using the older PV550 displays. Have a locked up comm port. Is there any hard factory reset procedure...
1,369
Hello everyone , I have an engineering station with step7 program. I can make the modifications from this PC for 7 PLCs. But now I can not...
1,931
