Comms Driver or Solution to allow interfacing between .NET and MicroLogix
Jul 2007
Kiruna
600
Hi there,
I am developing an application which requires interfacing to a PLC.I will be producing quite a number of the same machine each year. I would like the "openess" to allow comms to multiple peripherals such as printer, Credit card readers as well as database connectivity and am exploring the possibility of developing the user interface in .Net (C#).
Has anyone any suggestions/recommendations on a way to interface to a PLC via .NET enviroment? OPC etc? Can it be done? Is it expensive?
This will do exactly what you need:
http://sourceforge.net/projects/abdf1/
There is also a more in depth option that includes the above driver:
http://sourceforge.net/projects/advancedhmi/
These are all done in VB. If you are using Visual Studio, you can add a VB class libary, add the necessary files from the above projects, then the driver will show up in the toolbox after a build.
If you are only using C# Express, you can download VB Express, create a class project, add the files, then compile to DLLs which can be referenced in your C# project. I have done this for the DF1 driver, along with documentation on usage, and it is listed on Ebay under "DF1 driver for .NET"
I no longer have an option to select df1 path and was wondering if anyone has ran across this. I can configure in RSLinx Classic and see the PLC...
2,048
I have an existing WinCC Server & 7 S7-315 PLCs project installed. The client has now requested additional data to be lifted from another process...
101
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
106
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
391
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
92
