Comms to SLC 5/03 via 1746-UIC
technolog
May 2015
Ohio
320
I've made a successful connection to this machine before, only a few weeks ago. Now, RSLinx refuses to find it. I've tried two different 1746-UIC converters. I've tried two different ethernet cables (I'm right in thinking they're standard ethernet cables, aren't I? They certainly have RJ45s at both ends, I've rebooted. The switch on the UIC is in the correct position (RS485(DH485) -
closest to the green LEDs).
I think the problem might stem from when I was altering com port settings in Device Manager last week to try to establish communications between GML Commander and an AB 1394-SJT10-C servo drive.
Can someone tell me what the Device Manager com port settings are for their UIC, please? Any other help or advice would be gratefully received.
Disregard. I was using a Graceport-style connector on the panel door and the cable to it had been trapped and damaged by the door.
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
Been years since i have went online with a slc, but I am using a usb to serial convertor and tried the df1 driver and the other drivers and none...
496
Hi, I’m just after a couple of pointers on testing comms between SLC PLCs in a test environment (i.e. not on a live plant). For a typical...
2,740
Hello, I have a problem and certainly just one of many to come as I become more involved with PLCs We've got a panelview 1000 connected to a SLC...
3,186
I have a SLC 5/05 with really slow Ethernet comms. It is on a network with three Proface screens but comms is just as slow when I connect directly...
3,934
