Communicate A-b Cpu 5/03 To Pc
JAYALA
Guest
J
HI I HAVE BEEN TRYING TO COMMUNICATE AN A-B SLC 500 CPU 5/03 TO A PC
NO LUCK DON'T KNOW IF I NEED SPECIAL SOFTWARE TO COMMUNICATE WITH THE
PC . CAN YOU GIVE ME SOME POINTERS,
ALSO THE GML COMMANDER WHAT 'S THE USE OF THIS SOFTWARE OR HOW
CAN IT BE IMPLEMENTED
THANCK YOU IN ADVANCE
JAYALA
Easiest way to communicate with AB SLC 5/03 you need RSLinx software
( Professional or Lite ) and cable AB parts # 1747-CP3,if you don't have it it's easy to make , you need two 9 pin female connectors
WIRE Connection:
9-pin female 9-pin female
3-----------------------2
2-----------------------3
4-------------!---------6
!---------1
6----------!------------4
1----------!
7-----------------------8
5-----------------------5
8-----------------------7
Connect cable to PC COM1 and Channel 0 on SLC
In RSLinx you have to configure driver for SLC.
VUFU
Hello, first of all, I want to say thanks to everyone who is seeing this post. I have a problem with an SLC 500 5/05 processor. I need to download...
2,801
Hi, is that anyone know the pin layout for the communication cable from Mitsubishi Q00UJCPU (6 pin mini) to any Schneider HMIGXU (D sub 9)...
1,121
After reading through some older threads and checking out my old friend GFK-2224, it sounds like an RX3i CPU can talk Modbus TCP, this much I'm...
1,482
1,616
Hello All: Does anyone know the comm protocol for Q00J(by the programming port on cpu panel)?Although I know some manuals have noted that the...
2,444
