Communicate s7-300 via profibus
arthur.hauer
Nov 2016
Paraná
34
Hello there folks!
I need to access certain DB data from slaves (IM 151, CP342-5) connected to master (CPU 315-2 PN/DP) via Profibus-DP. They're all connected to a supervisory system, which can access data from all modules.
The problem is i'm allowed to program the master onlyo_O. I came up with 3 possible solutions: Global Data (GDC), routing and PUT/GET (IM 151 not capable of S7 connection).
Considering that GDC requires that every module has the latest hardware configuration (which i can't download to slaves), is routing the only solution? If so, how to access data from an OPC server connected to master?
Post Scriptum: Sorry for broken english. Please, if i omitted any information that may help, feel free to ask. I intend to answer ASAP
Yes, you should be able to use PUT/GET. Since you aren not allowed to make changes in the slaves, it seems to be the only way to do it.
I assume that the "IM151" is an IM151-7. In this one you have to activate the "test, commisioning, routing" in the setup of the DP port.
Hi Everyone, I want to know how we write the data to s7 200 plc from S7 300 plc on MPI Network Cpu 315-2dp Cpu 224XP i use SFC 67 and SFC 68 for...
4,465
Hi All I want communicate PLC S7 300 by VB.net and use Libnodave pass usb mpi 6ES7972-0CB20-0XA0. Can do it? If can please guide me. Thank you.
3,296
Hello all in this forum, as you can see I'm new here this is my first post. So here it goes: I want to know if someone has done this before...
1,856
Original system was PV300 and ML1000. Comms is via 1761-NET-AIC. That setup has been working for 10 years or so. Connecting laptop via standard...
2,654
I want to communicate S7-300 CPU315-2DP Plc and 4 pieces Unidrive (Control Techniques) inverters (32bits ) via profibus.Only I will send speed...
1,734
