Communicating mitsubishi q series PLC Q02h with E100
p_ramesh_nmdc
Sep 2007
BACHELI
OPen to all,
Pl help me out to configure the Q series PLC Q02H and E100 digital display unit, so that they both communicate with each other. I am using Melsoft series GX developer Ver 7.01B
I assume you have a copy of E-Designer in order to program the E100. The communication between the PLC and the E-100 is set up here.
When you select a new project, the "Project Properties" window will appear. Here you should click the "Change" button and set the "Operator Terminal" to E-100 (and whatever version the terminal is. Then in the controller systems section, click the "Change" button set "Controller 1" to MELSEC -> QnA/Q CPU Protocol or QnA/Q C24 (depending on how you are communicating between the PLC and the HMI, then finally if the processor is in Q mode or QnA.
See the file attached for more info.
M
Actually it's Q or A mode, not QnA. And 99% of the Qs out there are in Q mode. Q in A mode was a bit of a specialty item.
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,388
I am trying to make communication possible between the mitsubishi FX-2N and a proface HMI, ST401. all the other areas are working fine eg i can...
3,913
I am unable to establish communication of GOT with atlas copco controller. Controller supports JBUS protocol and GOT has Modbus. GOT is...
3,574
Hi all, I want to communicate with mitshubishi PLC CPU Q06HCPU which is connected with the QJ71E71 ethernet module. From the QJ71E71 manual I...
4,147
hi all i am working on my project with mitsubishi FX1N PLC and GXdeveloper ver 7. when i write the new program in the PLC, and run it, I am not...
5,985
Marty Young
M
