Communicating to drive using SoMachine
electro89
Mar 2012
Canada
106
I'm using SoMachine, which runs Codesys V3. I'm using a Schneider M258 connected to 3 Leeson SM2 drives via CANopen.
I have imported the EDS, but now I'm not sure what to do. Read through the SM2 manuals on CANopen, but still can't come up with a way to talk to it.
What I'm trying to do is tell the drive to start/stop and set a speed.
I'm pretty sure I need to use the SDO_WRITE function block to write to some SDO's, but not sure how I would send the values.
Hopefully someone has some insight on this because I've been searching for days and can't come up with a solution
thanks!
You will need the CANopen manual of the Leeson drives for all the CANopen registers.
2 ways of controlling CANopen devices , either PDO or SDO . PDO is Producer-Consumer and SDO is Client-Server.
If you are using SDOs , you can use the Read/Write CAN_CIA blocks but you will need the Idx / SIdx / Data length of the Leeson drive parameters.
For PDOs, the .EDS will allow you to use the available TPDO , RPDO or map your own . You can map these PDOs to variables to be used in your code.
Hi Mohua,
Can you expand on this a little?
I'm implementing a SCX11 Oriental Motor Controller to the Schneider M238.
http://www.orientalmotor.com/products/pdfs/opmanuals/HM-60080E.pdf
The PDO from the .eds are as shown:
Do I simply assign variables that act as 8 bit commands? Should "Create all SDOs" be enabled?
Thanks,
Stephen
Stephen,
As a test you should be able to see the default values change when your inputs/outputs are active (provided node ID, baud rate , cabling etc. are all correct). This is the PDO method ( continuous polling of data).
Variable assignment is just a name.
For more information on the motor, you should contact the vendor.
Hi, I am trying to see if I can connect an Omron CJ2M-CPU32 PLC to a A1000 Yaskawa drive. My Yaskawa sales rep says yes with the addition of an...
2,505
This is the first time I will be attempting to communicate with a VFD (ethernet). Anybody have any sample programs with a small description of...
2,516
To All - I have a Powerflex 700 that I am configuring via the HIM, this is a stand alone unit - not on a network. Thus, I am thinking that I...
14,372
Hi all, I am upgrading the controls on a tablet press and want to communicate to a Danfoss FC302 drive using the channel 0 on the Micrologix...
5,648
Dear All Please help me about Below picture problem.PLC not communicating proper.
188
