Communicating to Panelview+ with RIO
Nov 2007
london
68
Has anyone set up RIO comm's between a PLC 5/20 and a panelview Plus 600 HMI using FactoryTalk View Studio Machine addition?
I'm writing a simple application but am stuck at stage 1.
I've been messing about for hours and not got anywhere with it.
RIO can be a real pain with PV+, are there any other comms options available to you ?
I'm trying to put a HMI on a AB PLC 5/20. I dont know what other options I have.
( I dont have much experience on AB )
What I what to do is replace a DL20 message display with this PV600+
Do you have the full AB part number of the processor?
The PLC 5/20 has DH+ as standard, I would go down this route if ethernet is not an option for you.
Regards..
Regards..
I thought RIO and DH+ was the same thing. (yes I'm that inexperienced on AB )
It's Cat No 1785-L20B PLC-5/20
So for the runtime I use the DHplus, DH+ ?
Do you have the add-on comms module for your PV+ to allow RIO/DH+ comms? They are expensive as I remember.(if you have this then use DH+ for runtime).
How far away in the PV+ from the PLC, and how many tags do you have? (you could use a serial connection if PV+ is local to PLC,but would only recommend for a low tag count)
How was the original DL20 message display connected?
Shaun.
Don't even think about using RIO, it's archaic to use for HMI applications. Use DH+, you just need to buy the add-on card for DH+/RIO communications (the card can do both).
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,573
Wow, it's been awhile since I've been on here. But, I'm so glad this forum exists. I know, no one really likes the AB panelview component HMIs...
3,893
Installed a Panelview + a few months ago. Used to replace a PV standard that worked for years but was failing. This is on a mature DH+ network...
2,502
I'm trying to backup the panelview program on a panelview 1400e. I'm a complete newbie. I have a serial cable with a 25 pin on one end. I have...
11,189
Could someone please help me figure out what's missing here? I have an ML1400 and a PV+600 both connected to an ethernet switch. If I connect...
6,059
