Communication between Citect and Beijer E410 Terminalæ
Dariusch
Sep 2003
284
Hi everyone
I have a communication problem with Citect polling data from some drives through a Beijer E410 terminal.
The Citect is communicating with the E410 with no problem (Modbus TCP), if the drives is not on.
The E410 is communicating with the drives with the citict off.
But when I do some data exchange from the drives and Modbus, I get an error "1:erroe D".
The Port 2 on E410 is a RS485 and the drives is on that. Station 1 and 2.
The Port 3 on E410 is the Ethernet and here the Citect is on using the Modbus TCP.
So I get the problem only when I do configure the data exchange.
I get som commonication but I stille get the error and after a while the error is permanent on.
Someone who has an Idea???
Thank you
Dariusch
Hi, The simulator panel shows the Scada is connected. However, the pages don't read any tags at all. The PLC and Scada are taken from the live...
1,077
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,813
please what are the steps can i do in vijeo citect to communicate to plc m340 ? with details please ....
4,793
Dear all, I have an existing CITECT SCADA v5.4 which is quiet an old one and have to communicate with GE Fanuc Rx3i PLC..........in going through...
4,970
Hi, I'm student and for my degree I must to create project which will control one plant. I have twido plc TWDLAE40DRF and citect scada v6.0. I use...
38
12,386
