Communication between Festo CPX and Rslogix 500
Snap25
Dec 2014
Michigan
237
I have a few inputs going into this festo I/O module. How do I go about setting up this module to communicate with with the 5/05 PLC ?
I've made minor modifications in the logic in a few programs, nothing to advanced. I'm just having a hard time grasping the concept of how to get them to communicate and why random inputs (not the valve outputs) are connected here and not to the allen bradley PLC.
I might be sign up for an Rockwell EtherNet/IP course to grasp this topic a little better.
Do i need a festo software as well?
Anyways, if anyone wants to try to help me understand, I appreciate it.
Festo
Cpx fb 32
Cpx ab 8 kl 4pol
PLC
1747-L551B/C 5/05
Hi
I think you might be a bit of bother.
I was actually setting Festo on Ethernet ip today and clx
I may be wrong but slc does not support Ethernet ip
I have used the cpx on device net was th slc but never over Ethernet.
Again I am open to been corrected and I hope I am.
You may be able to use a message block but I have never seen it on slcto a Festo cpx over Ethernet
Donnchadh
I do have other options.. I have a a different Festo manifold I can use for all the air actuated outputs and wire it into an output card in the panel and then just run the inputs that are going into the current Festo I/O module to the plc as well
I would be more hard pressed on figuring this out if I was using 5000 but this machine is just tying into an existing panel that has a few slots available on the PLC rack that they want me to utilize.
All of our new panels use 5000.. but that still doesn't solve my problem with being very inexperienced with networking šŸ™ƒ
The SLC-5/05 uses the Ethernet port for upload/download, inter-controller messaging, and connectivity to HMI and SCADA software.
It does not support I/O control over Ethernet. Only the ControlLogix family of controllers from Rockwell do that.
While it is possible with some devices to emulate I/O control using MSG or EEM instructions in the SLC-5/05, I never recommend it. It is almost never worth the effort and is never as reliable as actual ControlLogix I/O connections.
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
42
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
101
129
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
125
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
309
