Communication between Mitubishi fx2n and Servo Over RS485
plcman
Aug 2004
Wolverhampton
Hi
Does anybody know if it is possible to communicate with CT Unidrives from a Mitsubishi FX2n over a RS485 Network. If so any advice would be greatfully recieved.
Regards
Alan Edwards
Yes a FX2N PLC can communicate over RS485, you do need a optional BD board or a special module.
You must only write a program for the communication protocol.
A good example is deliverd within the manuals.
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
43
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
105
135
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
142
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
313
