Communication between Protool & Simatic TP170A
VITAL99
Mar 2011
Doha
20
Hello All
I need to get the Backup of TP170A for this I tried PROTOOL and PROSAVE and configured communication parameters via COM1
Gives Error Message: Could not established the connection
The software I am using are Simatic ProTool ver. 6.0 SP2 and Simatic Prosave ver 7.0.0.1, Windows XP SP3,
What are the possible causes of this problem ? help me out. Thank you
VITAL
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
31
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
91
116
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
119
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
306
