Hi all,
I have S5 PLC connected to the Multilab Celox through CP524 but the connection does not work.
I tried to go online to the CP524 to check its communication parameters but I could not. I tried this using the COM525 program on a PG and connected online to the CPU but I could not make the parameters transfer from the CP524 to the PG.
Questions:
1- How to go online to check the CP524 parameters?
2- What is the cable configuration between the CP524 and the Celox?
3- What are the recommended parameters for interfacing the CP524 to the Celox serial interface?
4- Is there a method to test the serial ineterface between the CP524 and the celox?
Best regards
Questions:
Best regards
