Communication between SLC 500 and SLC 5000
What SLC500 do you have. ( SLC5/01,02,03,04,05?) There is no SLC5000.
Do you mean ControlLogix, CompactLogix,FlexLogix?
How far apart are the controllers?
I know this is an old post, but why does the distance between the controllers matter if they are on the same network ?
Propagation delay much ?
< about 50' can accommodate a serial connection. Depending on which SLC there are a number of other communication protocols to choose from, each with their own distance limitations.
imlogedin, forgot about the trolls. You can do this real easy.use the handshake method. Just Thank the folks here who really tried to help you and shake their hands!!!
and just move on! or JUST MOVE ON!!!!
Bet regards ,Steve
imloggedin doesn't deserve to be a member with his childish attitude, he found his answer elsewere but still from this site.
Hello. I am in the process of designing a new project and I was able to successfully go online with the SLC 5/03 using a 1746-UIC cable through...
1,504
Hi, I have a machine with AB SLC 5/05 PLC and it already has its “Ethernet” port utilized for plant network. Now I'm designing one more panel...
2,816
In my case I was having panelview900 connected to SLC 5/03 through DH485 using AIC+ Advanced Interface Converter (1761-NET-AIC), an Isolated Link...
1,835
I have 2 SLC500/04 The master has it´s own I/O The slave has it´s owns I/O if master has an Input on, i want the slave turn on an Output. how...
4,920
Several months back we installed a Red Lion G315 HMI to communicate with a AB SLC 5/03 attached to the ethernet network via an AB ENI module...
4,492
