Communication between toyopuc PC10g and Fx5u
Shaun34
Feb 2024
Selangor
Hi, I am trying to send data register type (D) from Toyopuc PC10g to FX5u. Does it possible to connect both plc using fx5u features which is simple plc communicating setting? If yes, Do i need to configure some settings in toyopuc pc10g side?
You have not said what type of connection i.e. Ethernet, 485, 232 etc. the FX5 has a built in ethernet & 485 (this port is generally used for programming) however, you can set it for non procedural or Modbus but make sure you can connect via Ethernet
If using Ethernet then perhaps Modbus TCP.
Aternatively use one of the special adapters i.e. 232 BD board.
Cannot help on the other PLC
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
27
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
87
114
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
116
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
306
