Communication CP 243-1 by internet
mulderm
Jun 2003
Netherlands
298
Hello,
I have a S7-200 plc (CPU222) with a CP 243-1 ethernet-module connected on my home network.
I can communicate with the plc using Microwin installed on my notebook everywhere in my home by a ethernet-connection.
Now I will communicate with my plc when I have my notebook connected on internet somewhere else
example on my holiday-adress.
Is this possible?
Can I using portforwarding on my router and how must I configure this in MicroWin?
Greetings,
mulderm
You just need a static Ethernet IP address that can be seen over the internet. Most ISPs can arrange this for you but usually you don't have control over the IP address that is assigned to you. We,our customers, access our controllers over the Ethernet all the time but we have a block of assigned IP address at Delta so the IP addesses are fixed. These IP addresses are not protected by our firewall so the customers can easily access our controllers. If your PLC is behind a firewall then you may need to fuss with your firewall to permit the Microwin to pass on the static IP address and at the port it uses.
On the Microwin side you just need to set the IP address of the PLC to that if the fixed IP address. Note, the performance will drop. Response times will go from about 10 ms to 50-100 ms depending on the internet activity and number of hops.
Peter,
I have a static IP-adres assign to my CP 243-1.
Example: IP adres in CP 243-1 is 10.0.0.0
Internet IP adres (my provider) is: 98.111.222.333
So how must I configure this in MicroWin or Router(portforwarding?)
mulderm
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
332
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
34
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
170
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
