communication for s7-300
mohammad2060
Apr 2014
iran
30
hi
i have a question about communication for s7-300:
in the following diagram can be implemented communication link without any problem ? antenna is mikrotik and have ethernet port.
"radio link" does not say much, does it ?
If you can have TCP/IP connection to the various CPUs, then you con connect to it for programming and SCADA functionality.
If you can ping the CPUs from the SCADA PC, then yes.
my question is general , This system does not exist in reality to I ping cpu for test .
my question in different way is :
Each station has profinet port while antenna have ethernet port , do can connect Them to each other ؟
If there is a TCP/IP connection, then yes you can have communication between the PC and the S7 CPUs.
If the system is some kind of router, then the routers IP address must be specified in the HW Config of the S7 CPUs.
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
123
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
189
Hi! I'm trying to communicate with an old Kinetix 300 drive that is fully functioning. Is there any library I can use to monitor this drive with...
436
491
I have a project including S7-300 CPU 314 2PN/DP and this CPU will communicate with Promass 83DP. I tried to connect the flow meter through the...
2,927
