Communication from Iconics to PLC5/30 over DH+
lpanek
Dec 2013
Rochester
Hello,
I have a PLC5/30 unit that controls an existing machine. I need to communicate to it from Iconics Gen64 SCADA software. I was told that DH+ is the only option. I was planning on using 1784-U2DHP adapter cable and Kepware AB OPC Suite but I am not sure if it is possible to set the Kepware software to recognize the adapter and use it for communication. Unfortunately I do not have PLC5 hardware or the adapter available for testing. I have to come up with a solution and will be able to verify during the SCADA startup. Has anyone done something similar?
Thank you in advance for your help.
Hai All, We are trying to communicate allen bradley L33-ER processor with Iconics OPC server suite 5.5.Can someone tell me what are steps we need...
958
Dear All, I have a KUKA Palletizer machines having Iconics Genesis SCADA installed on its PC. It remained closed for about 7 to 8 years. We are...
965
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
41
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
34
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
41
