mahmoud shahien
Dear Experts ,
I have a system which contains 10 PLCs (1214C CPU) each PLC with GSM module (Teltonika RUT955) and 2 SCADA PCs at different locations (attached the Architecture) and I need to establish communication remotely between the 2 main SCADA and the 10 PLCs over GSM, I will use static IP SIM cards at each PLC.
The client has the below requirements:
- Siemens PLC should be communicated with SCADA system on specific Schedule Time.
- In normal condition (if no any Alarm), each site will communicate with SCADA system four times a day.
-There should be assign an option in SCADA system to poll the data of any site whenever he require.
-If any Instrument value will change to its Alarming stage or any other critical Alarm take place, Then that site should communicate with SCADA system and transfer the information immediately.
- Low data consumption.
So, according to the A/M system, which the best protocol you suggest that we can use?
Can Profinet communication comply with the requirements, or what is the best cost effective solution to comply with the client requirements?
Thanks.
Thanks.
