Compact/Control Logix RPI Recommendations
kb19791
Jun 2010
wi
So we have been using compact and control logix for some time now and no one has looked into the effect of RPI on a module by module basis.
The modules currently use their defaults as they are inserted into the rack. We use 1769-IA16 modules quite often and the RPI of the modules is defaulted at 20ms. Analog modules I believe are typically defaulted to 80ms.
We are reading in running contacts from motors, limits, door sensors, level indicators, etc... Analogs are typically 4-20ma valves, flowmeters, vfd's, etc...
Does anyone know of a place to find guidelines in regards to required speeds reading in discrete/analog I/O signals in an automation environment?
Thanks Much
this might not be the answer that you're looking for – but it's pretty important stuff IF (big IF) you're working with fast/high speed applications ...
as for analog input signals – the RTS (Real Time Sample rate) is probably more important than the RPI (Requested Packet Interval) ...
http://www.plctalk.net/qanda/showthread.php?p=391975&postcount=1
and if you're working with COMPACT-Logix (as opposed to CONTROL-Logix) - and if you're using Periodic Tasks with priorities higher than 6 (in other words, priority settings with numbers lower than 6) - then you need to know about the COMPACT-Logix system's Dedicated I/O Task ...
http://forums.mrplc.com/index.php?showtopic=26162&p=125399
and if you're working with CONTROL-Logix (as opposed to COMPACT-Logix) then probably would be interested in the COS (Change Of State) capability of your digital input modules ... this is usually turned ON by default – which means that your RPI settings don't really need to be set "fast" in order to give you "fast" updates ...
263
Hello, I’m looking to control a bipolar stepper motor using a stepper motor drive and a compact Logix PLC. Can anyone point me to how to program...
3,653
I want to network (ethernet) Control Logix with two Compact Logix; is that possible?
2,761
Hello, For my general information and knowledge, how is querying and storing data from a AB PLC (Compact or Control Logix) typically...
7,418
Dear all, i am using compact logix l18er and control logix l63 i want to use message instruction in between this to i am not getting proper...
3,824
