Compact Logic EDS File
ArikBY
Oct 2003
Oranit Israel
1,434
Hello everybody.
I try to connect between Omron to AB Compact Logic by Ethernet/IP.
For that I need the Ethernet/IP EDS file of the Compact.
I searched AB web site with out success.
I will appreciate if someone can lead me to rights place
I use 1769 L23E-QB1 firmware 17
Thanks in advance
Thanks for the reply.
If you will try to search for my PLC you will see nothing there.(and other CLX)
I tried it before I asked for help.
Thanks again.
I looking for Ethernet/IP EDS File.
What you send is EDS file.Those file can not installed as Ethernet/IP EDS File.
If you search for Ethernet/IP EDS File for my PLC you can not fine it on AB web site.
Because the assemblies you need are for I/O type devices.
Controllers simply don't have them pre-defined.
You may have a better luck to initiate CIP connection from CompactLogix if Omron provides these assemblies like some other PLCs do
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
129
Trying to understand how to send email or text messages for alarms. Anyone have example code for this?
262
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,436
In assets center the firmware revision 30 is not available for 1769-L33ERM controller. Revision 32 and 33 are available though. What’s the best...
1,174
Hello everyone I have an Allen Bradley Compact Logix 1769-L18ER-BB1B. I have several processes that I would like to start based on time of day...
2,691
