compact logic to panel view 1000
knucklebucket
Feb 2013
Greeneville, Tennessee
54
having problems at work. power outage and everything back up except one machine. has compact logic and a panelview 1000. keep getting a write error to plc. able to communicate to both via laptop? but not to each other. any ideas.
If none of the objects are functional, there is no connectivity between the HMI terminal and the CPU.
Can you "Test Runtime Application" from your PC's FTVS development application?
If successful, verify the terminal's Network Connections and the Network Adapter settings (No DHCP and obviously a configured Static IP Address); also verify the CompactLogix Ethernet Port (module) for Static IP Addressing, address which is compatible with the terminal's one (identical first three octets).
Hopefully there is no "managed" switching and/or IT "supervised" routing which became unfunctional at the time of the power failure.
If nothing obvious, try re-downloading the tested .mer file, this time with the "Replace Communications" options checked; this might do it.
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
126
Trying to understand how to send email or text messages for alarms. Anyone have example code for this?
257
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,430
In assets center the firmware revision 30 is not available for 1769-L33ERM controller. Revision 32 and 33 are available though. What’s the best...
1,171
Hello everyone I have an Allen Bradley Compact Logix 1769-L18ER-BB1B. I have several processes that I would like to start based on time of day...
2,672
