Compact Logix as serial DF1 slave
a_racioppi
Jun 2010
Whangarei
HI there, I need that an RTU (DF1 Master) polls some data from a Compat Logix PLC (DF1 Slave) serially. I don't seem to find an application note on how to configure the Compact Logix. I understand that in older PLCs the register of the N7 type were used. Any tips? thanks in advance
All ControlLogix family controllers can emulate PLC/SLC addressing for Boolean, Integer, and Real numbers.
There's a short description of the "Map PLC/SLC Addresses" feature in the Logix 5000 Design Considerations manual (Publication 1756-RM094) on page 98, and a good online reference attached to the Help button on that feature dialog box in RSLogix 5000.
I was wondering if anyone knew of a card either Allen Bradley or an after market that allows a compact logix to communicate over serial using...
1,711
hi guys, I am having a problem regarding the communication between a micrologix 1100 & compact logix using the serial port.I have configured a...
6,217
I am looking at a way to communicate with a serial device from my compact logix over ethernet. I have 4 devices, normally accept a a serial...
4,069
Dear All, communication between compact logix 1769-L31 and Indusoft 6.1 +sp4 on serial protocol is possible? If possible then which driver to...
4,399
Hi All I am using Compact Logix L35 E processor's serial port as a Modbus Master by using Rockwell's provided drivers for Modbus. I was...
5,468
