compact logix/control logix
The Selection Guide is a great start.
ControlLogix and CompactLogix are the two main branches of the Rockwell Automation Logix 5000 programmable controller family.
ControlLogix is the big system and process controller. It uses a Bulletin 1756 chassis, into which CPU and network and I/O modules are placed. The controller typically has only a USB or RS-232 port, and network modules are added to the system chassis.
CompactLogix is the smaller machine-level controller. It uses a "snap-on" expansion I/O bus, rather than a chassis. There are several different models with different network options.
Both controller families use the RSLogix 5000 editing software. There are several different editions of this software that support various languages and features, but the Relay Ladder Logic language is by far the most popular and widely used.
There's an older Rockwell Automation product family called "MicroLogix". Don't be confused by the similar name; MicroLogix controllers are small members of the SLC-500 product line and don't use the same instruction set and editor as CompactLogix and ControlLogix.
272
Hello, I’m looking to control a bipolar stepper motor using a stepper motor drive and a compact Logix PLC. Can anyone point me to how to program...
3,669
I want to network (ethernet) Control Logix with two Compact Logix; is that possible?
2,762
Hello, For my general information and knowledge, how is querying and storing data from a AB PLC (Compact or Control Logix) typically...
7,430
Dear all, i am using compact logix l18er and control logix l63 i want to use message instruction in between this to i am not getting proper...
3,827
