Compact Logix L35E
cjh
Mar 2003
Cumming, GA
235
I'm using a Compact Logix L35E. I "believe" that you can use a standard commercial compactflash memory card with this processor (question that I forgot to ask when I bought the processor..duh..).
Has anyone tried this before? Easier for me to buy one at Best Buy on the Am Ex than generating POs and all that jazz...
Thanks.
Yes, we have used 'off-the-shelf' CF cards in the L35E. We didn't run into any limitations. However, this may be card manufacturer dependent. So I wouldn't buy 20 of them until I'm sure one works first.
Keith
A-B offers their own labeled ones to fit applications that need extended temperature ratings that match the controller, or for installations that need to be validated with identical hardware.
I have used about six different brands with the L35E and L6x controllers and have encountered no problems. The biggest one I used was 256MB.
I would recommend getting a major brand like Lexar or Sandisk and stay away from cheapos and store brands.
So you can go up to 256M with flash cards on the Compact Logix? I understood the spec.s to say that it was limited to 64M?
I think the spec means it can only access 64M of memory. You can put a 256M CF card in but you won't be able to access the top 192M or address space.
Keith
That's what I was hoping to hear. I imagine it will be difficult to find 64M CompactFlash cards in the not-so-distant future.
Hey Guys, Just learned Rockwell stopped selling these two processors as of 12/2020. The web page recommends moving to the 5380 platform. Are...
1,703
Hi Sir , I came to know from the forum that you are a genius in rockewell controls . I have a question on Allen Bradley compact logix L35E...
1,482
I have two L35e processors i want to send message to and from. I just want to do data read. Condition from one plc and see it on another plc. I...
2,234
Hello All, I have an issues with Compact Logix l35e's ip address failing. I am able to set the address and connect to the processor with a Redlion...
3,060
i need help reading analogs from a compact logix l35E, using an LS HMI xp30BTA. Can anyone help... I am using a df1 serial for communication. I...
1,148
