CompactLogix 1769-L30ER with 1769-ASCII Card
haylow_89
Apr 2017
Ontario
Hello,
I am having some issues telling my ASCII card to send out data.
Right now I am using a Serial-USB and using hyper terminal to receive the transmit data.
The card will eventually go to a printer but this is a test station to tell me if i am setting the correct ASCII commands so the printer can work.
I have attached with this post my settings with my serial port, hyper terminal, the ASCII card and the basic logic from AB manual for the card.
The OK and RX0 light on the card are a solid Green(When i connect via hyperterminal the light will stay solid and turn off when i disconnect) but the TX0 light has never turned on.
I am so lost i dont know where to start.\
There is data (attached file) on the local card 7 but i cant seem to work....
Thank you in advanced.
-David
USB-Serial COM Port Settings.png Hyperterminal Settings.PNG Data on the ASCII Card- CompactLogix.jpg Basic printer Logic from AB Manual - CompactLogix.jpg 1769-ASCII Card Settings - CompactLogix.jpg
Hello Friends I need to replace a Micrologix 1400 L32BWA with 1 1762-OB16. I had thought in a 1769-L30ER, 1 1769-IQ32 and 2 1769-OW16. But...
2,415
Hi guys. I have some problem.I want to use AB PLC Control YASKAWA servo motor through MP3300 EtherNet/IP Communication Module. Now I download...
2,161
Hi All~ I have a case (designed by my boss But he has left the company) Please refer to the attached picture...
2,395
Hi, I am Akash. I am currently working on a PLC upgrade project from micrologix 1500 type to compactlogix 1769LRP. I have migrated the whole...
5,424
Does the CompactLogix 1769-L30ER use a battery for memory backup or does it have internal flash memory?
9,846
