Compactlogix and Citect
R.Mati
Nov 2010
Melbourne
25
Hi All,
I have an Allen Bradley PLC (Compactlogix L31) with serial communication into my PC's COM port.
T am trying to read some data from this PLC into CitectSCADA, I have used ABRSLINX driver as a commmunication protocol but not sure how to read a specific address(TAG)from PLC.
My data in Citect is like that:.
------ Boards ---------------------------
Board Name: B1
Boards type: ABRSLINX
Address: 0
the reset of fields are Empty .....
------ Ports ----------------------------
Port name: P1
Special Opt: AB_DF1-1
the reset of fields are Empty....
------- IO Devices ----------------------
IO Device name: Compactlgx
Address: AB:LOCAL,0
Protocol: ABRSLINX3
Port name: P1
the question again is: what do I need to put in Address field of Varabile Tags form so I can read the tags from PLC.
hi again
Hi again,
Still wondring if someone could guide me to the right driver to use to communicated with Compactlogix.:mad:
I am not familiar with Citect, but the Logix Family is Tag based. So, you need to check the Documentation for the proper format to enter the CompactLogix Tag Address.
Stu....
Hi All, I am trying to communicate Citect 7.1 to CompactLogix L30 PLC. I am able to read basic datatypes from the PLC , but structures are not...
3,370
If I want to use TCP/IP for communication to AB PLC with Citect, Which driver should I use? ABCLX TCP/IP?? What's the I/O address format when...
5,181
HI List I am starting a new Citect project with Compactlogix as controlers, I have some trouble finding the right driver, has any one tryed this...
2,381
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
73
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
148
