Compactlogix and control logix communication on ethernet ip
MERAJMJ
Aug 2012
mumbai
Hi Guys
We have two below controllers with us and we want to establish a Ethernet I/P communication between them to exchange to exchange datas
1. 1768-L43 Compact logix with ENT module.
2. 1756-L72 Control logix with ENT module.
Do we need any more extra module on both side or else how we can simply communicate directly with each other on ethernet IP if possible??
The CompactLogix ethernet module will be a 1768-ENBT module.
For the ControlLogix, it can be one of several possible part numbers: 1756-ENET Series B, 1756-ENBT, 1756-EN2T, or 1756-EN3T.
The most common of these is the 1756-ENBT.
The method for data exchange between ControlLogix family controllers over a network is called "Produced/Consumed Tags". This is very well explained in the ControlLogix online Help, in the User Manuals, and in many discussions here on the Forum and in the RA Knowledgebase.
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
944
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,134
Good Evening, I'm loading a recipe into a Rockwell ControlLogix or CompactLogix CPU via Excel, this is all working fine. Is there anyway I can...
2,053
Hello everyone, It's been a while I haven't dive into PLC programming (more than 5 years) and I wasn't doing it alot as programmer. I am now...
1,849
Dear All. I need comm between Compactlogix/Controllogix with PNOZ m1p ETH. What we need the communication option? or can be connect direct? many...
1,186
