CompactLogix Controller resetting IP Gateway at machine startup
squiggz
Apr 2021
Asheville, NC
23
I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B CompactLogix controllers. One works great and the other has an issue. When you cycle power to the machine, the PLC resets it's gateway IP to 0.0.0.0. So, I have to go in and change it every time we do this (which happens enough for it to be an issue) and change the gateway IP in order for the NATR to produce the alternate IP address. This does not happen on the other machine. Is this just a weird hardware problem or is there something I can do about this?
Any advice is appreciated. Thanks.
Been a long time since i've done anything except simple edits and troubleshooting, but this seems familiar.
Does the PLC have a SD card? If so, as weird as it may seem, I believe the answer was to fix your comm settings and then perform the backup to the SD card. I know it makes no sense, but I believe that fixed the issue for me on a project i had to start up years ago. Hope it helps!
Looking at the controller properties, I think there an SD card in there. I need to wait for tomorrow to investigate it further. Thanks.
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,091
Hi Everyone, I am a bit new in working with AllenBradley systems. I have a situation where an Compactlogix 5330 L30 controller is installed with...
1,879
Hi We are looking to replace the temp control system on our main oven. we currently run a eurotherm 2416 PID Controller with a single TC but are...
3,135
I have been trying to setup a connection between a 1769-L33ER and a WAGO 750-881. The WAGO PLC is part of vendor equipment. I set up a Generic...
1,162
Hi there, I am fetching some data(basically energy consumption-kWh) from Schneider make power monitor EM7230 over a modbus with CIP generic...
20
8,516
