Joe Bob Briggs
I'm programming a CompactLogix project (1769-L32E) and ...it's my first time with RSLogix 5000. I need to write some configuration info to a couple of module profiles just once ...when the logic executes the first scan for example. There doesn't seem to be an S:1/15 First Pass bit or tag or ??? I can easily use the Power Up config of the controller to run a Power Up routine, but the help file only mentions that this routine runs "after an abnormal power-down/power-up during RUN mode". Does it also run when somebody switches to "RUN"? How do I solve my "write module profile config data once on first scan ...normal start *OR* upon a power up after a power loss"??????
Thanks a mil!
JBB
Thanks a mil!
JBB
