Compactlogix L2 to powerflex 40p cip message
alfman96
Nov 2011
canon city, colorado
Hi All,
I have a quick programming question I thought you guys might be able to help with. I have a compactlogix controller with 4 powerflex 40p drives with 22-com-e cards on them connected together over ethernet. I want to be able to poll the dc bus voltage, amps, and temperature of the powerflex drive. I have the programming manual, and have searched the knowledge base trying to find why this doesn't work, and it sure seems like it ought to. I setup a MSG instruction with the following parameters for the amps:
(see the attached pictures. This was originally sent off as a email with pictures inline)
The fan1_amps tag is a real. The read message appears to happen and without errors, but instead of a reasonable number when the drive is running it goes to a really small number like 3.42e-43 (the drive parameter itself says a reasonable number, say 5-13 amps). Do you see any obvious reasons why what I am doing is not going to work or give the right values?
Thanks,
alfman96
Try changing your Tag from a real to an INT or DIN. I do not think parameter data is sent as a real. I think the decimal place is implied
Good Morning , I have a CompactLogix L33 and several Powerflex 753 Drives ( Ethernet ). In my RS Logix 5000 Tree I have all the drives. In...
2,065
Good Morning , I'm working on a project that I may need to change the acceleration rate according to which recipe is being ran. I took notice...
2,238
Good Morning , We have been running a machine , PLC and PowerFlex 525 for over a year. For some unknown reason , I have a Yellow Triangle on...
4,479
Good Afternoon , I am working on a project on the desk , and I am getting DC Bus Voltage , Current , and Fault Codes from my PowerFlex 525 to...
6,680
Good Morning , I am working on a project with some PowerFlex 525 drives. I am using CompactLogix 1769-L18. I took notice that the tags that...
23
22,542
