PowerFlex 753 and CompactLogix L33- What is DeviceLogix ?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I have a CompactLogix L33 and several Powerflex 753 Drives ( Ethernet ).
In my RS Logix 5000 Tree I have all the drives. In those drives I have....
Slot 4- Ethernet / IP
Slot 5- Safe Torque Off
Slot 14- DeviceLogix
What is DeviceLogix ? and why when I go to download, that box is checked saying that it is different than the online drive ? What is DeviceLogix actually doing ?
Thanks so much guys ,
It’s in the 7 series drives, the E300 OL relays and (I think) the SMC-50 soft starters. I think of it as an embedded micro PLC inside of the drive. Function block programming or ladder programming, but only around 500 instructions max and maybe a dozen or so different commands. It is capable of PID however and, if you get a 24VDC aux power card for the 750, it can operate without the rest of the drive being powered.
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
109
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,366
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
458
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
565
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
724
