MDK Member M Join Date Mar 2024 Location Kent WA Posts 1 Mar 25, 2024 #1 How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
robertmee Lifetime Supporting Member R Join Date Feb 2008 Location NC Posts 2,020 Mar 25, 2024 #2 DPI loss is set to fault drive by default. Change it to Hold last. On a 755 it's parameter 865. Not sure on a 753. This is assuming your HIm is on DPI port 1 which is usually the default.
