Powerflex 753 AOI with Modified DataLinks
ChadPLC
May 2023
Vancouver
I'm working on a project (AB PLC, L85 v34) where we'll have 20 motors installed, all controlled by powerflex 750 series drives. We need specific data for trending, so the datalinks are modified. This is causing the Data type to change from the standard "AB:powerFlex753_ENETR_Drive:I:0" to "AB:powerFlex753_R_xxxxxx:I:0" where the x's are different for each drive.
I created an AOI for drive mapping & control, but the change in data type is causing issues with the AOI definition as I can't use the standard powerflex definition now.
I know I could copy the drive data to an internal UDT first and then use that in the AOI, but I would be creating 40 new tags with that UDT data type in that case and I'm looking to avoid that.
Just curious if anyone on here can suggest a better solution. Thanks.
Rockwell knowledgebase ID: QA63944 for further explanation on changing datalinks and data type.
I know with the PowerFlex 755 you can use message instructions to get whatever data you want. I built an AOI with a scattered read message inside the AOI that gets the data I want, and I don't have to set up any datalinks on the drive. The 753 might be similar.
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
106
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,358
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
455
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
561
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
719
